Hey everyone,
so i was trying to follow this (Siri Kurzbefehl für den Nuki Opener - so funktioniert es) tutorial that basically let’s you open your Nuki Opener via a Siri shortcut. While i followed all the steps i also had to set up and put in the API Token in the shortcut. Now the problem is that i’ve done that but when i try and use the shortcut i get the following message:
{“suppressedExceptions”: I,“detailMessage”: “Your access token is not authorized” “stackTrace”: [1}
I have checked all the boxes in the API token menu and also tried and delete it and create a new one; i still get that error.
Anyone with some ideas maybe?
