Nuki Opener Unlocks Twice Instead of Once in Continuous Mode with AutoUnlock Enabled
Hi everyone,
I’m experiencing an issue with my Nuki Opener when both Continuous Mode and AutoUnlock are enabled. When I ring the doorbell, the main door opens twice—once immediately and then again after around 30 seconds to a minute. Ideally, the door should only open once when I ring.
The problem is solved by activating only one of the two settings but this control should be integrated to avoid the problem for other users.
Hello Giuseppe, thank you for your information. We will check this more in detail.
Best regards
Marcel
