FYI: It took me a while, but my Tegui 1380/4 can be installed with the Opener, following the Tegui T-200 guide. Works perfectly.
Is it the same installation scheme as the T200?
yes, just follow the same numbers from the T200 and it will work for the 1380/4
Installed and working. Thank you so much.
Hi, after a year of running using the T-200 configuration, now the buzzer on the phone no longer sounds. Do you know if something has changed in the app to make this happen?
