You know that you can program the TCS to switch on/off Automatic door release
Automatic door release*
If this function is activated, an incoming door call
directly triggers the door release. Shortly press the
function button. The red LED blinks. The door release
automatic is activated. Shortly press the function button
again. The red LED expires. The door release automatic
is deactivated.
These alternative settings can be adjusted by your
qualified electrician.
