Nuki Opener registers a ringing action every minute
The Nuki Opener registers a ringing action every minute, although no loud ringing can be heard and no one presses the button. Everything else works as it should, but the ring to open function is very annoying for my neighbors because the door opens every few seconds and buzzes when I’m in the geofence and ring to open is activated. Anyone have a similar problem or a solution? I’ve tried different variants and pulled the cable, only when yellow is pulled off does it no longer recognize any ringing.
There are more people experiencing the same issue, only in a different thread. Seems like you need to call support, that they fix the software somehow.
