this feature would be really great!!
In our apartment building there are three separate entrances. Each of them is equipped with a bell. Iâd like to be able to open/ring to open all entrances separately. This is possible today by adding three Openers next to my intercom. But this should also be possible with one Opener thatâs capable to send three different door opening commands to the BUS
Do you Have a Photo or Diagramm , how you connected the Wires?
Seems we have a very similar System, but even after ( at least ) 7 config. im still not able to open the Door.
At the Second I unplug my Cable at L , everything goes wrong :-/
How come this is not a feature already?
Is just sending two string of code instead one on the bus.
Record two opener string and save them. What it is? 3kb of data?
Ouch - I just ordered the Nuki Apartment package, not realizing that this situation isnât supported. I have a Fermax 101CI15B, which is in the list of supported devices, and is just a simple analog system which can open either door depending on which one buzzed (street or building door). As far as I know, this is very common in Vienna, and without this function, it makes the whole thing very limited for me. I may have to end up returning the whole package.
@Juergen Wouldnât it make sense to mention this unsupported case in the compatibility check that I especially went through to check?
There are many different methods how intercoms deal with multiple doors. Some methods do work with the Opener, therefore you better give it a go, try it and return it if it does not work.
So I hooked it up today - it only works with one door. It seems to act as if the second doesnât exist. I will experiment a bit more tomorrow, but I really hope this feature can get added at some point.
Just tested a bit more, and it actually works for both doors. Just used the default wiring, and if I ring at either door, I get a notification in the app, and I can tap open to open the door which Iâm at. Works great!
Thatâs true, if you have multiple dry contacts. But if you are on a communication bus the cabling is the same.
At least you could provide the API to let Domotics freaks like me take care of the configuration.
We donât need no gui!
Me waiting for Nuki team to take a step in customerâs direction.
Was this for a bus or analog wiring?
Periodic Ping
Hy Developers
I have almost the same problem, by ringing at the Gate, my opener opens the gate but not the Bulding door.
To the convenience of my Costumers, we have a nuki smart lock 3.0 at the Building entrance.
Unfortunatly the opener cannot be configured to close his internal relais and, at the same time, send a Opening signal to the SmartLock.
We are now destroying a Fob witch we conect to our Smarthome (KNX) witch now handels the Gate and the Building Door. Not realy a great solution, but Nuki isnât reali up to the task, regardless the first requests were made back in 2019. if anybondy needs a Picture how i modyfied the Fob, let me know
Any updates?
I bought the Nuki Opener since the website indicated it was compatible with my intercom (Urmet 1172-55 Signo), but now I find myself in a situation where one door opens but the other one doesnât.
What should I do? The website doesnât provide any indication that itâs not compatible with multiple entrances, and the support team was only able to tell me that they are aware of this issue and apologize for the inconvenience.
The most annoying thing is that there is even this forum where programmers can understand the real issues with the products, but then they donât care.
Itâs 2024 now, can we get an update on this? It should not be too complicated to make this work, I think I have a pretty good idea being a software developer myself.
Just give us a setting âopen on any ring signalâ or something similar. That would mean that it acitvates the buzzer also for the apartment door, but I think that would be a great workaround.
