Hi all, I’m new here. So, thanks for your patience.
Is it possible to send “Open” command by API to Nuki Opener?
Thanks!
Thanks!
Yes it is possible. Here is the API Doku:
https://developer.nuki.io/page/nuki-web-api-1-3-0/3/
This would be the request to unlock the door via opener:
http://{bridgeIP}:8080/lockAction?nukiId={openerID}&deviceType=2&action=3&token={secretToken}
Best regards,
Peter
Hi Peter, thanks.
I assume this command will work over LAN, so “bridgeIP” is the local address of the bridge.
Right?
Is it possible to call the same API outside from LAN?
Is there a Cloud service we can pass through?
If your bridge is also accessible from outside, then this command should also work. i.e. you could register a port forwarding rule for your router and redirect a request for a specific port to the local ip address of your bridge.
But I would advice against it. In my case I’ve a raspberry running in my local network that communicates with the bridge. The bridge is not accessible directly from outside (only via the app)
Just to clear things up:
@pego mixedan example from our Bridge API with the link to our Web API.
Those are 2 different things with the first one working locally in your LAN and the second one only after activating Nuki Web (and there the Web API) as a “cloud service”.
In the second case you can find the command describe here in our Swagger instance for the Web API:
POST /smartlock/{smartlockId}/action/unlock
