Hey guys,
I try to find out what exactly the functions of the Nuki Opener doing, as the support could not answer the question.
Purple/Blue: should work as a relay and just close the circuit
But if it’s going to bell suppression it’s different. I thought the green or yellow wire will just shut off if the suppression is activated but this is not the case cause it needs the ring signal of red/black.
If yellow or green is connected to my bell (8v ac), the bell is not working properly anymore cause the voltage is changing, also there is a strange behavior with the suppression:
If suppression is activated there is no ring detection, suppression can’t be deactivated and the nuki app is crashing sometimes. I have to disconnect the whole cable, red/green or purple/blue to get it back on track.
Seems there is a problem with the 12v ac from the door opener and the 8v ac from the bell.
Support changed things but couldn’t tell me what they did and send me here ![]()
Best
