I have got a Fermax intercom. The model is 3321 and this model is not included in the list of the opener compability models provided, nevertheless I have tried the models Fermax 3311, Fermax 3325 as well as Generic Bus (Fermax VDS/ADS) configurations, with all their possible combinations and I can’t make it work.
I attach a picture of my device (blue wire (-), yellow (L), red (+), white (video-), green (video +).
Thanks for your interest.
I made all the connection combinations indicated by the app during installation in the intercom models that I have described in the previous post. In all cases it shows me the same error message “The installation of your intercom system does not correspond to the standard”.
Hi there,
I would appreciate if you could help me …
These are the two connection combinations that I have made with the “Generic Bus (Fermax VDS / ADS)” model, following the steps indicated in the app. In all cases it shows me the same error message “The installation of your intercom system does not correspond to the standard”.
I would appreciate if you can give me some indication since right now I have the feeling of having thrown the money.
Hi!
I am not sure if this intercom model will work (I did not find any information if this is a VDS model), but the wiring scheme to try is the one for Generic Bus (Fermax VDS/ADS). The wiring according to your pics will not work. Try the VDS one, if this is not working, the intercom is not compatible.
I have managed to put the opener into operation in this model of intercom, in case it helps someone, I have made the connection as indicated in the guide for the Fermax intercom model 3390 and it works correctly.
He conseguido poner en funcionamiento el opener en este modelo de intercomunicador, por si a alguien le sirve de ayuda, he hecho la conexión como se indica en la guía para el intercomunicador Fermax modelo 3390 y ya funciona correctamente.
