Nuki Opener degrades image quality of Siedle BTSV 850-03
After connecting the Opener to a Siedle BTSV 850-03, the image quality suffers substantially. A lot of noise is introduced, which was not visible before.
Same here.
Same here.
The noise can be reduced by shortening the NUKI cable. Try to make it as short as possible. This will reduce noise.
Any chance you could show your setup please!
Thank you.
I also got the BVPC 850-0 W. How did you set it up in the app and how did you wire it?
Sorry not supported anymore. I moved away from Nuki Opener.
Thank you for responding!
What did you pick in the end ?
Ring
