Hello everybody!
I’ve been trying to install a nuki opener in my intercom but i cannot make it work. It is a 2 wire bus system and it says it has no polarity. This is the intecorm:
I install it as a generic bus (tried different ones) and several times I recieve a bluetooth error.
When I have to press “open” in my intercom, it is all the time loading and then I get the bluetooth error. When I check the connection status everything is alright.
I have the “loading button” all the time.
(Translation: to configurate the opener you must connect via bluetothh or with a nuki bridge.)
(Translation: To manage your Opener, you must be next to the bluetooth signal)
I am less 1 meter away of the bridge and opener…
If someone has a similar intercom or system, or someone know how to fix the bluetooth problem I would be very grateful.
Thank you very much!
