hi, i’m trying to integrate the opener on this phone. It consists of 4 cables (positive, negative, microphone and speaker) so far I have been trying with various bus configurations, but the only configuration that seems to work fairly well is with the bus generic. the problem is that it won’t open the door (everything else seems to work fine) could someone help me?
I have the same problem. I think that is not compatible with opener
Hi anything new about opener working on auta digital?
Something to do with this?
Any news?
Hi, any update on this?I have an auta compact basic digital, tryied generic bus config with no success any hel is wellcome !!
Same here with the Auta 700105. Please help ![]()
Any updates? I’m also trying to connect the opener to Auta 700105.
Hi Lluis Pascual.
Did you finally integrate the opener with your Auta phone ?
I have the same model
No, finally i used another system. You can try to replace auta for a compatible one…
Thanks a lot for your answer.
Which model of phone did you install ? My sistem has 4 wires
Julián
Julian , in this case for auta phone i finally used a system different than Nuki, but if you check with specialist maybe you can replace auta phone for a compatible one. Regards
