I have few questions.
- continuous mode for check-in
I am not sure how the feature continues mode for check-in works. I would like to have continuous mode activated during the whole staying of the guest. If I look at the description there I have the possibility to set for how many ours from check-in time it would be active. If I set it to ‘off’ will it be active until the check-out time or?
2nd questions is, if I change manually a check-in time of the NUKI to be 2 hours earlier, will this also reflect NUKI opener (continuous mode)?
- If I have same day booking, the PIN for keyboard is generated automatically as requested per Smoobu, but Smoobu fails to catch PIN immediately after. It worked as I was told perfectly few weeks ago. Can it be done in this respect something?
Br
Igor
