Nuki Opener Alexa Alerts
Just thought I’d post so other users were aware - I’ve been looking for a solution to connect Nuki Opener and Alexa, so that when my intercom is rung, Alexa announces the press / chimes (in the same way Alexa devices do for their Ring doorbells). Unfortunately my intercom buzzer / the Nuki chime are both not loud enough for my home.
I stumbled across this service today, which allows me to do exactly that in conjunction with IFTTT:
https://www.ijpuk.com/solutions/read/amazon-alexa-doorbell-skill
You can test it out for free, but to use it regularly it is a paid service at £20/year. Unfortunately, IFTTT is now also a paid service - so the solution isn’t exactly the cheapest option, and it’s still dependent on IFTTT’s (relatively minor) action delay. Still hoping for a local solution between Nuki & Alexa or other platforms (SmartThings / HomeAssistant), but for now I’m delighted to have a solution, even if it costs a little bit more.
Hello Neil,
There is a verified “local solution between Nuki (Nuki Bridge) & Alexa (Amazon Echo)” using Athom Homey as hub. Homey can run the integrations with Amazon Echo devices (https ://homey.app/en-us/app/com.amazon.alexa/Amazon-Alexa/) and Nuki devices (https ://store.homey.community/app/nuki.homey). A simple flow allows “Alexa announces the press /chimes” when your “intercom is rung”.
Thanks for letting me know! It’s a little too much for my budget just now, at about 300 EUR for the hub, but I’ll bear it in mind for the future.
I have build it for me with nodeRED and also with a lokal php Script and IFTTT.
Here is the nodeRED solution. Only German: Node-RED: Der Neustart – Alexander Palm aus Hannover (Bemerode)
Alex
Thank you for this, I will have a read!
Hey at all.
I’m looking exactly for the same solution. I want Alexa to give me a notification when the opener received a signal from the doorbell.
Will there be in the future a integration to Alexa as a doorbell, this will solve the problem on the easiest way. All other workouronds are nice as well. But in German not the yellow from the egg. (Das gelbe vom Ei) :joy:
Nice weekend
I have done it in my ioBroker. Now Alexa announces a ringing doorbell.
