Hi, the FAQ says it is not compatible with the Finnish locks. However looking at the installation instructions, it does seem that it is compatible.
Why does it say not compatible?
Finnish profile cylinders require bore wholes which the Nuki mounting plate does not support. However, not every door in Finland has a such a cylinder. If you have a standard Scandinavian cylinder it will work.
I actually ordered anyway. It fits on the LC102 but the distance from middle of the lock to door frame was too narrow in my case and the nuki was hitting the frame. The scandinavian and finnish is mostly the same, the screws are just a bit lower/higher.
Ended up returning the nuki ![]()
