I need some help here. My problem is that I have a Nuki 3.0 pro with a door sensor installed. I just installed it out of the box a couple of days ago.
Now my problem is, that if Nuki opens the door using the auto unlock feature it will lock the door again after a couple of seconds even when the door is still wide open.
I don’t need my door to be locked again after I arrive, because the door can only be opened from the inside if you don’t have a key.
So my best case scenario would be for Nuki to unlock my door and I just shut it without actually locking it, so I can easily get out again later.
I already checked the firmware and everything is on the latest version.
Thank you for your help in advance!
