Nuki Lock State API
I have just installed a Ution Nuki Pro for a client and am integrating it to work with their Loxone Smarthome system.
Following the API instructions provided by Loxone i have managed to get the Virtual outputs working (loxone can now lock and unlock the door)
However the Virtual Inputs are ‘Returning no Values’
Loxone technical support have looked over my configuration and it all seems correct as per their instructions (see page here) loxone-library
Does anyone know what local page I need to read from for the Virtual inputs, i have it so far as http://192.168.0.159/NUKI_state.html
But this reports a 404 error.
Check the Exampel, you need to trigger the getState Output
Thankyou for your reply Klaus
What example are you referring to?
Where can you trigger getstates outputs?
