Nuki HomeKit number of turns
Hi! I’m using Nuki with HK and I have autolock with geofence with it and I’m finding an oddly behavior: sometimes it locks twice (720) and sometimes it locks just once (360). Why is this happening?
Thank you!
If you are using 360 degrees locking (1x turn) and you are locking an already locked door, it will be locked twice (2x).
Autolock on geofence exit always sends a lock command regardless of the current state of the lock, which leads to the behavior that you described.
The thing is that I don’t lock the door when I get out, so it just should trigger the auto lock once.
Never mind, was due to an automation trigger twice. Thank you! :grin:
