Nuki Bridge not connecting to Nuki server anymore
Maybe someone has an idea. My Nuki Bridge does not connect to the Nuki Server anymore. I tried reset and reconfiguration already. Also tried different WiFi networks as well as tethering over my phone to rule out a local network issue. No luck! I see that the last connection of my bridge was tonight around midnight. Since then it does not connect anymore to the Nuki servers. The led also blinks twice every 10 seconds accordingly.
Any ideas what I can do?
Thanks in advance for any ideas
Mario
Same issue. Started a month or 2 ago. New hub sent out. Wifi is good to the device.
Its been working fine until last month or so and Support at this stage cant resolve it.
No change to my ISP or router settings. No firewarlls or VPNs
As a result I dont have any remote access
I have to re-plug the bridge every month in order to be sure that it works fine.
I need to replug the bridge every once in a while due to connection issues…
Do you have the API exposed? It seems that may be the issue in my set up.
I need to check 100% as it may be coincidence but turn API off and it connected once power cycled
This has worked fine since march so it looks like Nuki have changed something in recent firmware
They seem clueless. Needs more investigation
Last year it was 1x every 3 month
after: 1x every month
now: 1x replug every 2 weeks :frowning:
Dear JĂĽrgen,
That will be fine, if you let customers to know what to do in this case. Not redirecting to “support” which is not 24/7.
I have problem with my Nuki with build in Wi-fi module and it says “Cannot connect to the Nuki server. Try again later.”
I reboot it like thousand times, calibrate it, turn on and off wifi module and still cannot connect to server.
You have a serious problem with this feature as I’m reading this forum.
Solve the problem for customers, let everybody know how to fix this problem and don’t redirect them to customer service where they have to wait.
MAKE A SOLUTION TO BE VISIBLE AND WORKABLE. That will stop people from typing here ….
