I’d appreciate any insight into this weird issue I’m seeing.
I have a Nuki 3 lock and a Bridge. The Bridge is obviously connected to my WiFi network. There are several Ubiquiti APs around the house and yard.
The bridge has an AP just above it - say, 4 meters away, clear straight line of sight. But I noticed that it connects to a different AP, one that is in the yard of all places, and obviously gets poor connection quality. No matter what I do, it will not connect to the AP that’s near. Tried: (a) many reboots; (b) shutting off the yard AP (it would then connect to another, front yard AP, and then when the latter is shut off, does not connect at all); (c) “locking” this client to the closest AP using the Ubiquiti management.
No action makes it connect to the AP that’s right nearby. When “locked”, it would just not connect.
Help?! I’m at loss as to what could be causing this.
Thanks for responding. Yes, I tried that - see (c) in the original post. Does not work - the bridge just doesn’t connect to the “close” AP once I lock it to that one.
Thanks. I did try something similar: Turned off both other (farther) APs, to have the Bridge see only one AP - the one I want it to connect to. See (b) in the OP. No cigar - it just would not connect (at all), and would go offline.
I really don’t know what to make of this - why would it not connect to this AP. One long-shot guess - that AP is set to 2.4GHz channel 11, perhaps for some reason the Bridge would not connect on that channel? This is quite unlikely and far fetched but I’m at the end of my wits here.
