Nuki Bridge 2.0 Errorcode 15 WiFi broken
My Nuki Bridge 2.0 (or whatever the revised Hardware Revision from 2019 is being called) running Firmware 2.14.0 lost the WiFi connection. After a reboot it didn’t reconnect so I started the Nuki App to manage the Bridge.
The App reports that the Bridge is broken and Reports Errorcode 15. After several retries I can manage the Bridge and it looks like it doesn’t find any WiFi Networks anymore at all. A factory reset didn’t help at all.
Is there a bug with the Hardware of the Espressif ESP-WROOM-32 inside the bridge or a problem with the WiFi Firmware?
Error Message in German: "Diese Nuki Bridge ist leider defekt und muss ausgetauscht werden. Bitte wende dich an den Nuki Support. Fehlercode: 15.
Any ideas what Error 15 means?
The same thing happened to me 10 days ago. Any update that broke the product?
For me too: Fehler 15 / Error 15 with my nuki bridge. thats crap :frowning:
Nuki refuses to replace the product, this is obviously a software bug, not a hardware one.
I informed the seller (Tink) about that procedure and think it was my last nuki.
The original lock is already replaced, i used the Bridge with the Smartlock 3.0, which i bought 3 months ago at Amazon, luckily, i am able to return that crap.
nearly 3 Years of nuki seem to be enough.
This assumption is wrong. It’s a hardware defect and can’t be fixed with a software update.
That’s discussable. I will open it and extract the firmware and compare it with a brand new one.
But still: multiple customers are affected by this bug, which occurred in three cases ±7days
Planned obsolescence?
Then let us know what exactly is broken.
What does Error 15 means? Which component failed?
The Bridge consists of an ESP32: is there a Problem with this Part?
Maybe something in Common?
How comes so many brigdes fail at more or less the same time? Bad component or failed Firmwareupdate?
Most likely a problem with the power unit (transformer).
“Many” is relative. It’s 3 out of a 6digit installed base.
Thanks Jürgen for your reply.
I connected an usb-to-serial-adapter to the serial pin header on the nuki bridge and here’s what it shows.
Looks like a boot loop.
Can you tell whether your assumption on a broken transfomer is right or not from this output please?
I (471) cpu_start: Starting app cpu, entry point is 0x400811e8
I (461) cpu_start: App cpu up.
I (481) heap_init: Initializing. RAM available for dynamic allocation:
I (488) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (494) heap_init: At 3FFCBDF0 len 00014210 (80 KiB): DRAM
I (500) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (507) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (513) heap_init: At 40094F88 len 0000B078 (44 KiB): IRAM
I (519) cpu_start: Pro cpu start user code
I (202) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_st▒▒▒▒▒▒▒og scheduler on APP CPU.
I (563)H▒;▒▒▒▒▒’;K▒▒’;K▒▒’ܻ▒▒▒▒;▒▒▒▒;▒▒▒’;K▒▒’;K▒▒’ܻ▒▒▒▒;▒▒▒▒;▒▒▒’ܻ▒▒▒’ܹ▒▒▒▒;▒▒▒’ܻ▒▒▒’;▒▒▒’▒;▒▒▒’ܻ▒▒▒’ܻ▒▒▒▒
▒ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:6320
ho 0 tail 12 room 4
load:0x40078000,len:11624
ho 0 tail 12 room 4
load:0x40080400,len:6648
entry 0x40080764
I (32) boot: ESP-IDF v3.3 2nd stage bootloader
I (32) boot: compile time 17:47:10
I (33) boot: Enabling RNG early entropy source…
I (37) boot: SPI Speed : 40MHz
I (41) boot: SPI Mode : DIO
I (45) boot: SPI Flash Size : 4MB
I (49) boot: Partition Table:
I (53) boot: ## Label Usage Type ST Offset Length
I (60) boot: 0 nvs WiFi data 01 02 00009000 00004000
I (68) boot: 1 otadata OTA data 01 00 0000d000 00002000
I (75) boot: 2 phy_init RF data 01 01 0000f000 00001000
I (83) boot: 3 factory factory app 00 00 00010000 00130000
I (90) boot: 4 ota_0 OTA app 00 10 00140000 00130000
I (97) boot: 5 tmp_flash unknown 45 46 00270000 00180000
I (105) boot: 6 webpages unknown 40 40 003f0000 00010000
I (113) boot: End of partition table
I (117) boot: Defaulting to factory image
I (121) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x21188 (135560) map
I (178) esp_image: segment 1: paddr=0x000311b0 vaddr=0x3ffb0000 size=0x03648 ( 13896) load
I (184) esp_image: segment 2: paddr=0x00034800 vaddr=0x40080000 size=0x00400 ( 1024) load
I (185) esp_image: segment 3: paddr=0x00034c08 vaddr=0x40080400 size=0x0b408 ( 46088) load
I (213) esp_image: segment 4: paddr=0x00040018 vaddr=0x400d0018 size=0x851ac (545196) map
I (405) esp_image: segment 5: paddr=0x000c51cc vaddr=0x4008b808 size=0x09780 ( 38784) load
I (433) boot: Loaded app from partition at offset 0x10000
I (433) boot: Disabling RNG early entropy source…
I (434) cpu_start: Pro cpu up.
I (437) cpu_start: Application information:
I (442) cpu_start: Project name: esp-idf
I (447) cpu_start: App version: silicon/v2.13.1-12-gf345de9
I (454) cpu_start: Compile time: May 18 2022 12:32:17
I (460) cpu_start: ELF file SHA256: 2bf7fef37eafca68…
I (466) cpu_start: ESP-IDF: v3.3.4
I (0) cpu_start: Starting scheduler on APP CPU.
I (563)▒▒;
▒▒▒▒▒▒’ܻ▒▒▒’ܻ▒▒▒▒;▒▒▒;K▒▒’ܻ▒▒▒▒;[▒▒’;K▒▒’;▒▒▒;K▒▒▒;▒▒▒’ܻ▒▒▒▒;▒▒▒’ܻ▒▒▒’ܻ▒▒▒’;K▒▒’ܻ▒▒▒’ܻ▒▒▒’;▒▒▒’
▒▒ets Jun 8 2016 00:22:57
ho 0 tail 12 room 4
ho 0 tail 12 room 4
entry 0x40080764
I (0) cpu_start: Starting scheduler~▒▒▒▒▒▒▒[0m
I (563)▒▒;▒▒ ▒▒▒▒;[▒▒▒;[▒▒’▒;▒▒▒’ܻ▒▒▒▒;[▒▒’;▒▒▒’;I▒▒▒;[▒▒’▒;▒▒▒▒;[▒▒ܹ▒▒▒▒;▒▒▒’;▒▒▒’▒;[▒▒’▒;▒▒▒ܹ▒▒▒’ܹ▒▒▒’;▒▒▒▒ets Jun 8 "▒▒▒▒Ғ▒Ҫ▒j
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,▒pets Jun 8 2016 00:22:57
ho 0 tail 12 room 4
ho 0 tail 12 room 4
entry 0x40080764
I (563)▒[; ▒▒▒#▒▒▒▒▒▒;▒▒▒;K▒▒’;▒▒▒’;▒▒▒’ܻ▒▒▒’;K▒▒’;▒▒▒;K▒▒’ܻ▒▒▒’;▒▒▒▒;[▒▒’;K▒▒’;I▒▒▒;▒▒▒’ܻ▒▒▒’ܹ▒▒▒’ܻ▒▒▒▒;[▒▒’▒ets Jun 8 2016 00:22:57
ho 0 tail 12 room 4
ho 0 tail 12 room 4
entry 0x40080764
I (0) cpu_start: Star▒▒▒▒▒▒l▒▒on APP CPU.
I (563)H▒;▒▒▒▒’ܻ▒▒▒▒;▒▒▒’ܻ▒▒▒’;▒▒▒▒;[▒▒’;▒▒▒’ܹ▒▒▒’;K▒▒’ܻ▒▒▒▒;▒▒▒’;I▒▒▒;▒▒▒’ܻ▒▒▒▒;[▒▒’ܻ▒▒▒’ܻ▒▒▒’ܻ▒▒▒’ܹ▒▒▒’▒ets Jun 8 2016 00:22:57
ho 0 tail 12 room 4
ho 0 tail 12 room 4
entry 0x40080764
I (563)▒K; ▒▒▒1▒▒\▒▒▒;[▒▒’ܹ▒▒▒’▒;▒▒▒;K▒▒▒;▒▒▒’;▒▒▒’ܻ▒▒▒’ܻ▒▒▒’ܹ▒▒▒▒;[▒▒’;▒▒▒;K▒▒’;▒▒▒’;I▒▒’ܻ▒▒▒’ܻ▒▒▒’;K▒▒▒;[▒▒’▒ets Jun 8 2016 00:22:57
ho 0 tail 12 room 4
ho 0 tail 12 room 4
entry 0x40080764
I (563)▒I;▒▒▒▒▒▒;[▒▒’ܻ▒▒▒▒;▒▒▒▒;▒▒▒’ܻ▒▒▒;K▒▒’ܻ▒▒▒▒;K▒▒▒;[▒▒’;K▒▒’ܻ▒▒▒▒;▒▒▒’ܹ▒▒▒’ܹ▒▒▒▒;[▒▒’;▒▒▒’ܻ▒▒▒’▒;▒▒▒’▒ ▒ets Jun 8 2016 00:22:57
mode▒▒▒▒▒/YZ▒▒j
ho 0 tail 12 room 4
ho 0 tail 12 room 4
entry 0x40080764
I (563)X▒;▒▒▒▒▒7▒▒<?▒▒’ܻ▒▒▒’ܻ▒▒▒▒;[▒▒▒;▒▒▒▒;▒▒▒’ܻ▒▒▒’ܻ▒▒▒’ܻ▒▒▒’ܻ▒▒▒▒;▒▒▒’;K▒▒’ܻ▒▒▒▒;▒▒▒’;K▒▒’ܻ▒▒▒▒;[▒▒’ܻ▒▒▒’;K▒▒’▒ets Jun 8 2016 00:22:57
ho 0 tail 12 room 4
ho 0 tail 12 room 4
entry 0x40080764
I (563)▒[; ▒▒w▒#▒▒▒▒;▒▒▒▒;[▒▒’;K▒▒’▒;▒▒▒’;▒▒▒▒;[▒▒▒;▒▒▒’;▒▒▒’ܹ▒▒▒’ܻ▒▒▒▒;▒▒▒’ܻ▒▒▒’;I▒▒’;K▒▒’;I▒▒▒;▒▒▒’ܻ▒▒▒’ܻ▒▒▒▒
ho 0 tail 12 room 4
ho 0 tail 12 room 4
entry 0x40080764
I (563)▒▒;
A boot loop is what you usually see when an energy source does not deliver enough power to a circuit. So yes, still points to a defective transformer. You can simply replace the integrated transformer with any other 5V power source.
This would be the transformer
SMTSD S05P7-05W
This means, this is a 5 volt transformer with 1amp current.
That cheap china transformer caused those errors?
That’s a bit below that 5 volts, indeed.
Anyhow, USB (best source for stabilized 5 volt power supply) does work
Cheap parts means more complaints.
So, finally:
In case you are also suffering from the cheap power supply:
SMTSD S05P7-05W
There is a replacement/part by mean well (also manufacturing in china, but they’re known for power supplies.
So I would rather recommend to replace the power supply with:
Mean Well IRM-05-5 | 5VDC | 1A | 5W
Size of the old and new one for comparison.
The next steps are: Unscrew the plug, remove it from the old PSU and attach new wires.
The mean Well PSU might not fit perfectly in that plastic cage, but you can trim the the excess plastic with a plier.
Consider to use heat shrink! I mean, we are dealing with 230V AC.
There we go, after reassembling, that’s it.
