Nuki 3.0 Pro - WebAPI - Open door (iOS Shortcut)
Hello everyone,
I would like to open my Nuki using a shortcut on my iPhone.
Peter W. has created a very good guide with a ready-made shortcut (https://mobi-test.de/smarthome/siri-kurzcommand-fuer-den-nuki-opener-so-funktioniert-es/)
This guide also works. Unfortunately, the door is only unlocked and not opened (open door).
Unfortunately, I didn’t find a suitable command on the website https://api.nuki.io/#/ that would open the door.
Is there a WebAPI command for this?
I thank you :slight_smile:
Yes, you can do this via the “unlatch” action.
Please see the Swagger model for the options available: Swagger UI
action type = 3 for unlatch or open door.
Please ensure the correct setting for your door handle, that can be set up in the Nuki app (i.e. Lever, Knob or bar or Lift-up handle).
Hallo Poonam,
than you for your replay. Can you help me with what I need to enter or replace in the shortcut app on the iPhone?
Thank you.:pray:t2::blush:
Shortcut for unlock the door
What’s the setting for the door in Nuki App? Does this match the door you have?
You can check this in Nuki App under Features & Configuration > General > Choose door fitting
(attached screenshot below for your reference)
