Nuki 3.0 MQTT drops after a few hours
my Nuki 3.0 Pro drops the MQTT connection after a few hours and is no longer possible to reconnect.
Until I open the Wifi-Settings on the lock it is also no longer possible to ping it, but the connection via the app (also out of the bluetoothrange) is still possible.
The current installed firmware version is 3.10.7 and the WiFi-Infrastructure is based on Unifi.
Regards
Max
Hi , I also have mqtt issues. Same firmware, same lock. My WiFi setup is everything AVM (Fritzbox 7530 ax and 3000AX).
When I send a command via mqtt it sometimes takes multiple minutes to arrive at the lock.
Battery is on performance Mode.
On previous firmware’s everything was working great. Didn’t find a solution yet
I have the same problem. I can’t say if it’s related to a firmware update, but the error has only been occurring for a few weeks; I never had any problems before that.
