Not all states of door are reportet via MQTT
I have the latest NUKI Door Smartlock with Key Pad and Door Sensor. Its connected via MQTT to Home Assistant.
I wanted to start an automation when the door is opened (e.g. by using the correct fingerprint or typing in the correct code)
Unfortunatly there are no entities that I can use as a trigger. I have only Door Sensor which reflects the status of the door but nothing of door is locked or the latch of the door is taken back for opening.
How can I get to this information in Home Assistant?
Thanks and BR
Jo
