No LockState / LockAction on Nuki 2.0
Hi, if i try to get or set the lock state, i only get response
http://192.168.178.65:8080/lockState?nukiId=XXXXXX&token=XXXXXX
{ "success": false }
NukiFW: 2.30
BridgeFW: 1.11.3
the bridge is only 2 meters away
I could only reproduce this when the smart lock is not available (removed batteries).
Can you see the smart lock in the /info endpoint (with "paired": true)?
And could you also check connection status shown in the App please?
Yes the status shows paired in API and App but no interaction between bridge and smartlock is possible
@reik.braune Mmh, can you try to access /lockState once more and then send me a Bridge-log afterwards (via PM)?
After i try a reset from Nuki and Nuki Bridge now it works normaly
