Hi all! been using NUKI for some time now but… found a problem installing another opener on an old system.
The Intercom itself it’s not that old… but can’t find much information. It has been changed for a “new” one but the building is old… Here’s what I have:
It’s a Contera Starbell 1000:
(the side button on the handler is to active Microphone… people outside only hear me when I press that button)
The button that opens the door is that dark rectangle on the “base”.
Here’s the blueprint (with translation):
Hi Joao Cabrita, was you able to install Nuki Opener with the Starbell Contera intercomunicador? I’m planning to buy the opener and I was wondering if the opener is compatible after all. Thanks in advance.
So, long story short:
Remove the cable that’s connected to “5” and plug it one the connector that comes with the OPENER.
The cables from the Opener:
Yellow: connector that comes with the Opener (where you previously connected the cable from the existing doorbell)
Green: “5” (where you had the white cable connected)
Black: “4”
Purple: “4”
Blue: “B”
Red: “3”
