Hi.
I’m new in the Nuki Things, but Not new in IoBroker and Smarthome Things.
I have troubles to get my Nuki in Mqtt.
I use the Sonoff Adapter in IoBroker and round about 60 Sensors/Actors Works great with it.
In the Sonoff Adapter Shows Nuki only one Objekt: alive with Status true. So Connection is good.
I tried a other Mqtt Broker and the Nuki Shows all states and i’m able to lock/unlock.
But I can use the Port 1883 only in one instance, the Sonoff or the Mqtt Broker.
My Options to get the Sonoff and the Mqtt Broker both to Work:
1: migrate all my Things from Sonoff to MqttBroker. Then i Had Update all my Scripts to get them Work.
2: change Ports in Sonoff Adapter and the Ports in all my Aktors/Sensors
The simplest way is when i could Change the Nuki Mqtt Port to a other Port as 1883.
Is there a way or a Chance to Change it?
Thanks for your help
