I want to extend the lock ‘n’ go time over MQTT. But it seems that all lockActions are ignored while lock ‘n’ go is currently active. I tried to send 4 to the lockAction, this seems to be to have no effect. Also changed to unlock by sending 1 seems to do nothing. Any suggestions?
          As mentioned in the MQTT spec Nuki locks can only process one lock action at a time. i.e. you can not send another command while one is still active. In addition there is currently no possibility to stop a lock action via MQTT once it is started. I.e. you can cancel a Lock‘n‘go via the button on the lock, but not via MQTT or the App.
