Thank you for reading this small topic.
I only have some small questions regarding the MQTT API, and thank you for your kind response.
They all relate to values sent back from lockActionEvent.
What is code:
- 0,2,0,0,1
- 0,2,0,0,2
In the API document, there is no description for the first number to be a 0.
The API documents does not document value 0, it starts from 1. What is 0?
Then I’ve also gotten codes back, like:
- 1,0,623837184,0,0
- 2,0,623837184,0,0
- 3,0,623837184,0,0
What is 623837184 in the “Auth-ID: Auth-ID of the user” field?
When/why would that occur?
Thank you so much for your kind assistance, as these are the two last things I cannot decipher in the API ![]()
Sincerely,
Diederik
