MQTT activation failed. The MQTT connection was made by Server rejected. Error code: 88
I installed the ioBroker on my Raspberry Pi 5. Using the MQTT Server Adapter, I want to communicate with my Nuki Smart Lock 4 Pro using MQTT.
Port is set to 1883, as Nuki wants it to be.
However, my IP address from MQTT Server is 192.162.1.9.
This IP address probably does not fit the Nuki and therefore I get the following error message:
MQTT activation
failed.
Server rejected. Please check your
Configuration.
Error code: 88
Since I have independently trained over 70 devices in the WLAN to my IP address range, I do not want to use any other address range.
What can I do now?
A similar topic with no useful solution is available here:
Greetings Dominik
This is not a private IP range, but a public one and therefore not allowed (see MQTT spec).
Depending on what your infrastructure supports, you could try to add multiple IPs to your MQTT server or router (and use port forwarding to forward data to the MQTT server).
I use an AVM Fritz! Box 5590 Fiber.
How do I have to do exactly to use MQTT?
Greetings from Dominik
