Hello, after last Home Assistant updates Nuki integration don’t connect my lock trough Nuki Bridge. So I want to activate MQTT. I have mosquitto broker for MQTT and use it to connect zigbee devices with zigbee2mqtt.
When I open Nuki app and go to Settings>Smart Home> MQTT I want to click Activate button but nothing happen.
I have the same problem, I assume that you are not connected to the Thread network “correctly”. You need to enable NAT64, which is my case, is not possible with a Google Home Hub.
Now after Lock upgrade I can click Activate button but don’t know how to fill the fields.
I try:
mqtt://192.168.0.208:1883
192.168.0.208
192.168.0.208:1883
mqtt
mosquitto.
Don’t have more ideas what I can use. I don’t have password for mosquitto. I use mqtt://192.168.0.208:1883 in zigbee2mqtt.
Everytime I get 8E error.
I had some problems with connection too.
I just used my hosts broker ip (192.168.0.208, no mqtt:// or port)
And the username and password i set my broker with.
After 3 or 4 8E errors it finally connected.
The point is , your mqtt broker is probably not the issue.
I would check the logs in host to see if anything comes up (timeout of nuki or smth?)
