for a few weeks I got a problem when opening the door with Nuki.
The motor is blocked when I open the door. It seems that Nuki pulls the latch but tries to do so too far and then the motor is blocked because it’s not possible to pull the latch that far.
I already tried to calibrate the smartlock but it didn’t help.
Nuki pulls the latch until a certain resistance is met and compairs the position with the remembered endpoint from the calibration afterwards. If the expected endpoint is not reached, the motor must have been blocked on the way. Causes are usually slight changes in your door frame (weather, temperature, …) or wear of the cylinder/bolt.
Exact same issue here, with a brand new lock installed last Saturday (September 28th). This evening I tried to calibrate with closed door. I’ll report back in the next days.
Just to report I calibrated the lock (latest production, non beta firmware) two days ago with closed door and today it’s out of calibration again: it tries to unlatch the lock too far and lock’n’go acts weirdly until a new calibration.
Just updated to 2.6.3 and recalibrated with the door closed.
After few minutes my partner came back home, opened the unlocked door and… motor blocked. Nothing changed and unluckily few days ago the Amazon return period expired, so I have a lock which must be recalibrated continuously in order to be usable. What a disappointment.
[EDIT]
It’s been days that with the unlocked door, I never manage to open the door at the first try, I always get the “blocked motor” but I manage to open the door on the second or third try. This mean I can’t remotely open the door through HomeKit (the main reason I bought the lock for), since it never manages to open the door from full locked. The update didn’t change anything. Today, after updating and trying and trying (with no success) I got the prompt for critical batteries (after one month of use). Tomorrow I will try with Eneloop Pro batteries.
@Juergen Sorry, I’m a little late… just reporting that, after installing Eneloop Pro batteries, all problems were solved. OEM Duracell batteries were really unreliable. I’ll try Ikea LADDA 2450 which seem to be rebranded Eneloop Pro.
Does the eneloop batteries solved your problem? I’ve installed new batteries and in the next day my motor tried to jammed (same symptoms- slow start like at dying batteries) but somehow it managed to locked without errors (I have 1 level lock settings) did Eneloop batteries works for you?
