Make available every passcode typed on a keypad over API
Smart Locks with API support
Thanks to you API, it is easy to integrate your smart locks into a smart home system. But, as I can see, only the correct (accepted) passcodes are available through your APIs. If a wrong/invalid code was used, the code is not available for 3rd-party apps.
Let make available EVERY code typed on a keypad, not only the valid/accepted codes!
If a smart home gateway would be able to get every typed code over API access, your keypad become an universal remote device, it would be a keypad for the smart home system too.
  • Type a code (what is not valid by the NUKI system) to turn on the lights at the gate!
  • Type a valid code to open your NUKI lock, then type another code and open your gate or garage door with the smart home gateway.
  • User can control anything in the house with codes on NUKI keypads what his/her smart home system can control, when the smart home gateway has access to every code typed on your keypad, not only the accepted ones.
