lockActionEvent + Nuki Keypad 2 → trigger non-Smartlock actions
I am currently using the Nuki Keypad 2 in combination with a Nuki Smartlock 4 Pro.
I have set up for my keypad, using the Nuki App, certain Code IDs (“Berechtigungen”) with associated codes without the permission to lock (“ohne Sperr-Erlaubnis”).
I am using these codes to exclusively trigger things other than the lock in my smart home, e.g. a garage door. To do so, I currently listen for the corresponding MQTT lockActionEvent messages. For the Code ID without lock permission I get “3,0,<>,<<Code-ID 1>>,1”, while the Nuki Smartlock does nothing (and correctly so!). For the “regular” codes with lock-permission (say Code-ID 2), which trigger my Nuki Smartlock directly, I get “3,0,<>,<<Code-ID 2>>,1”.
I have read somewhere, that this behaviour is supposed to be a bug that will be fixed soon (https://developer.nuki.io/t/lockactionevent-tiggered-even-in-case-of-wrong-code-input-on-keypad/37326). Is that true? I would then no longer be able to use the keypad for non-lock events in my smart home, which would be a pitty! I love this feature!
Would I be able, after a firmware upgrade some time in the future breaks my setup, to revert back to my current nuki firmware?
In the MQTT specification document, https://developer.nuki.io/t/mqtt-api-specification-v1-3/17626, I read that it should be possible to: “Trigger something when a specific keypad code was used”. How would that work without lock-actions if the above avenue would be blocked?
Thank you!
Context: I am on Nuki Lock firmware v4.7.4 and Keypad 2 firmware v2.3.2.
I have lately seen reports of this function being broken with the latest firmware (link). Can this be confirmed? The following feature request seems to relate to this issue, see here.
…could NUKI please comment?
