I use a nuki 3.0 pro that is via MQTT connected to home assistant.
I tried to use a trigger for lock and go but it did not fire.
I tried to lock the door via app and via push button on the device itself.
Locking and unlocking the door via home assistant works fine.
I did some research. There is no event for “lock and go” on the event bus.
Hi Thomas, you have to read this:
https://developer.nuki.io/uploads/short-url/fcR2ntjSFMz3oHUMrIjYSU3g0O4.pdf
Add in your configuration.yaml:
mqtt:
sensor:
- unique_id: 12121212121a
name: "Nuki Lock Action"
state_topic: "nuki/XXXXXXXX/lockActionEvent"
An example of automation:
alias: Lock Action Event
description: Lock Action Event Automation
trigger:
- platform: state
entity_id: sensor.nuki_lock_action
condition: []
action:
- choose:
- conditions:
- condition: template
value_template: >-
{{ trigger.to_state.state.split(',')[0] == '4' and
is_state('switch.alarm_status', 'off') }}
sequence:
- service: switch.turn_on
entity_id: switch.alarm
