Laskomex LM-8 support
I have a Laskomex LM-8 handset. The process to open the door is:
  • Call from the main entrance
  • The handset is ringing
  • Pick up the handset
  • Open the door
I tried the simplified and the enhanced wiring for generic bus systems and I cannot make it work.
During configuration, at the first step where it says “Actuate door opener”, it fails to read the signal when I open the door. As you can see above, my intercom requires activation. Is this configuration supported by Nuki?
Here is the wiring without the Opener and with the Opener Enhanced setup.
Thanks,
Adrian
Hi, you resolved the problem ?
I have the same Laskomex LM-8.
Nuki wrote for me :
In general if a system is not listed as compatible, then it (most likely) will not work.
Nope, I returned it.
Adrian
I will be try Laskomex LM-8/I. are office function.
When you ring in house will open automatically.
With Sonoff swich you possible to control smart online.
I will try this way.
Did anybody connect NUKI Opener with Laskomex? I have MVC-6850.
did you manage to get anyone to release Laskomex? I wonder if the technology used is similar to another brand that is already compatible. We are already comfortable with the fact that I won’t have all the features.
Is there any progress on this matter? In Lithuania, Laskomex intercom equipment holds the majority of the market share. Support for Laskomex is the only reason preventing the return to Nuki equipment across all sites.
Are there any updates or any news at all after all these years since the request, regarding support for the Laskomex LM-8? :slight_smile:
Has there been any progress or new information regarding support for the Laskomex?
