Nuki Keypad
Notify if someone tries a wrong code on the keypad with a pushmessage
If someone tries to open the door by guessing the access code, this is recorded in the log.
It would be even better if a push message could appear on the connected phone so you could take action
Why is this feature needed?
Added security
Disable entry codes for a while if you see someone tries to guess a code.
True, I see it also, did check it before and did not see it, maybe it was not in an earlyer firmware or I just am blind (probably the last one) I’ll change the request because I would like to be notified. So a notification on the screen would be helpfull.
It would be interesting which code has been tried. So you can see if somone randomly tries to get in or uses a specific one. Also a notification of a user having a code but wants to access out of permission times would be nice. And if there have been more then 5 wrong attempts the keypad should be disabled for at least some time.
Nuki Keypad
Notify if someone tries a wrong code on the keypad with a pushmessage AND SHOW KEYPAD INPUT AND DEACTIVATE KEYPAD AFTER 5 WRONG ATTEMPTS
Added security
