can I create pin code for the keypad even thought keypad is not connected? We are waiting for keypad to be delivered. I am asking just because when I try to add permission via api to user for smartlock and add code I am getting this error:
“The supplied value ‘453423’ for parameter ‘code’ is not valid”
"The supplied value '13' for parameter 'type' is not valid"
You can overwrite the value for keypadPaired to true at https://api.nuki.io/smartlock/SMARTLOCK_ID/config and then set up PIN-codes like in my sample above, but there are some things you need to consider:
The Smart Lock will only recognize them when a Keypad is really paired.
So you can not see or edit PIN codes created that way in the Nuki App for now.
POST to smartlock/config needs all values to be sent, so be sure to not mess up any settings!
OK now it make sense because I get error with not valid type parameter so I was thinking that it is some fault on api side. I think that best solution will be wait for keypad.
I get keypadPaired:false even though the keypad is paired and working, why is that? Do I need to manually update config so this works (update config is also returning an error )
