Then Checked the Door Code via API and saw the timezone ID is different for each Smartlock
Mostly it’s 37 and 10, for 37 I found that it’s Berlin Timezone.
what is 10 ?
our smart locks are in Saint Barthélemy, the timezone is GMT-4 for this time.
is this the reason why the code does not work, if yes then what is the solution for this
10 is the time zone ID for “America/Manaus”, which is UTC -4, so this is presumably the correct one for your implementation. I’d recommend setting all of your Smartlocks to use this time zone; you can do that within the settings for the individual Smartlock from your smartphone.
Hopefully that will fix the issue.
Here is a list of supported time zones in case anybody else runs into this issue.
