Still impossible to update keypad pro 2, stays in 2.1.3. Since may. I tried to contact the support, no solution yet ( reset, log…)
Frequent deconnexion of the pad, everyday…
Any help?
@Okko Hi, what Bluetooth connection improvements have been made? Is the keypad now faster to react and doesn’t take 3-10 seconds to open the door? I’m talking about the non pro version.
Is the pro version faster in general? This can also be used with batteries and adhesives, right?
@oSIRus : Hello Kersten,
we have changed some settings for establishing the BLE connections between the Keypad and the Smart Lock. This leads to a faster and more constant timing for the initial BLE connection. In our tests we experience 1…2 seconds. In generell there should not be any connection attempt that takes longer than 6 seconds.
The changes are valid for the Keypad 2 and Keypad 2 Pro. Both Keypads have the same performance.
Regarding your additional Keypad 2 Pro questions:
Yes. Keypad 2 Pro can be used with Batteries too.
No. Keypad 2 Pro is designed to be flush-mounted. We are not offering adhesives for the Keypad 2 Pro.
We are looking forward for your feedback on the Keypad 2 Beta FW 2.3.0. You should have a faster and smoother opening experience now.
Original post has been updated with release notes for the Beta FW 2.3.2
This Beta includes major improvements for BLE connection setups and enhances the Smart Lock response time after pin code entry, fingerprint authentication or back button commands.
Please install this build and provide feedback via this channel - thank you
Thanks for the info! How fast is it now considering optimal placement and only a wooden door between? I’m considering buying the Ultra when it’s out but would really like to know the Keypad speeds beforehand (I mean the time between pressing the fingerprint sensor and the lock to start unlocking). I currently do not own a Nuki smartlock so I can’t try the new version.
how can I debug fingerprint not working (while code is working) - also rescanned fingerprint etc. Fingerprint sometimes works for short time after lock is rebooted
