Intergrate knx to nuki
What is the best way to intergrate nuki with knx,
A costumer from me have a hager iot.
But many time 's the aplets of disconnected on ifft.
Is there a beter way to get a beter connection.
at the moment i’m working on a (Gira) Homeserver Plugin to intergrate into KNX System.
But i think this doesn’t help you much …
If you’re completely desperate, you could also wire a Nuki fob to a KNX relais (e. g. a Weinzierl MultiIO). But that’s probably no solution to sell to a customer.
Thanks for the support, But my costumer has a x1 from gira.
:grin:
Can you tell me how to do this? I have a KNX relais and a Nuki Smartlock4pro, but how can I connect a remote to a relay? All I want is when I send a specific group adress over the KNX bus, that my Nuki unlocks
The basic idea is to solder two wires to the pins of the button inside the key fob and connect these wires to the output contact of the relay. However, you have to make sure that the relay output is floating, i. e. not connected to anything especially 230V. This is an ugly workaround. Your best solution would probably be to take a look at Keyless electronic door lock for smart access | Nuki The Smart Lock or Home Assistant.
Patrick
