Integration with lodgify
Integration with Lodgify
I’d like to have a connection between the lodgify channel manager and NUKI
Nuki should send an automatic message with the access to the lock via email to the guests staying at the house. Like Airbnb already uses it.
Why is this feature needed?
Because there are bookings from different sources and I need to send the codes manually unless people book via Airbnb which is usually not the case.
People book, two days before they arrive they get a code to open the door. This code is only active during the stay. So from check-in to checkout.
Every user gets a unique code.
According to Lodgify they’re working on a Smart lock Management System incorporating all major smart lock companies.
https://roadmap.lodgify.com/c/135-simplify-your-smart-lock-code-management
