Improve lock'n'go on doors with lift-up handle and door sensor
Smart lock pro 4th gen
The door sensor over rides the lock n go timer
Allow lock n go timer to remain after door sensor sees closed position
Why is this feature needed?
The door needs to be closed with me on the outside to lift the handle so the nuki can lock the door , as soon as the sensor sees closed the lock n go activates , there is not enough time to close the door and lift the handle.
So I can use the door sensor and still have use of lock n go
I changed the title of the feature request, because it only applies to doors with lift-up handle and smart locks that are paired to a Nuki door sensor.
On doors without lift-up handle the current behavior to override the max. timeout is the desired behavior. On doors with lift-up handle there should already be a short time span of a few seconds which gives you time to lift the handle after the door has been closed. This feature request is about making this timespan longer (until the max. timeout is reached).
Hi , thanks for the reply , this is a video I took of mine , this is with Lock n go delay set to 60 seconds , the kids struggle to lift it in time .
Door lock delay
