iHaus Integration
Coupling the iHaus app is done via the Bridge HTTP-API. You will need the following parameters for setup:
  • IP adress of your Bridge
  • Your Bridge token
In the Nuki app, you can search for your Bridge from the menu item “Manage Bridge”. By clicking on the Bridge icon, activating the API quick connection and the HTTP API, you will get the required parameters for integration.
Proceed as follows in the iHaus app: In the desired room, go to “+ Add” > “New devices and services” > “Nuki Bridge” and enter the API token of the Nuki Bridge. Afterwards your Nuki Smart Lock will be displayed under “found devices” and can be integrated into your Smart Home via LINKIT as usual.
Integrate Nuki with the iHaus App (in German):
