I have a Nuki 2.0 system and although I activated Nuki web account and enabled IFTTT channel, I have never received a notification though IFTTT. I asked to be notified when anyone unlocks the door, to no avail.
I use iphone Xs.
Any ideas?
Do you see something in your IFTTT activity feed? (Get Started - IFTTT)
If you send us your Applet ID we can also check the IFTTT error logs if we see something there.
There has also been a problem with refresh tokens on IFTTTs side in december, but if you (re-)activated the connection later, this shouldn’t cause your issue.
The phone you use should make no difference.
EDIT: Just saw that your Applet was created on Dec 22, 2018 so it may really be worth a try to disconnect and reconnt the Nuki channel in IFTTT and set up new Applets, if all other things fail.
Thanks the reply.
No activity in the feed.
I disconnected & reconnected the Nuki channel and will test again.
Hi. I confirm that it now works fine. Thanks
Hi my notifications is also not working
Where do I check that notifications,
Used test button in google forms, says notifications sent but didn’t receive any notifications
Here is my applet I’d “Customer”
