@Kunold thanks for your update. Could you update me on the failing Applet IDs via PM?
Update: It looks like we finally nailed down the remaining issue and the disconnection problem after 1 hour should be gone for all users. Please reconnect again and get back to me with your experience, if possible.
From yesterday seems that the problem is solved.
I made multiple triggers from IFTT and after the reconnect all work, also after hours (like now).
Thank you
Had been working fine since that latest fix, but I just got another disconnect email from IFTTT a minute ago. Anyone else the same?
Tested now… It functions well
Thanks. I’ve reconnected again. Will keep an eye out to see if it disconnects again and will update here if so.
Nuki disconnected from IFTTT again for me a couple of days ago (got the IFTTT notification email about it), and all Nuki applets were disabled. I’ve had to re-enable each individually. Is anyone else experiencing this?
I did have an internet outage for several hours on the same day the IFTTT email was sent - can an internet outage cause IFTTT to disable the Nuki connection?
Hi! Not fully brake up, but since a few days, some of my Applets don’t starting right or executing just some steps of a Applet, but don’t go fully through successfully, but without error message in the ifttt logs, it just stopped, or shows steps executed, what are in fact not executed!?
