I can't send commands to Nuki Ultra Over HA and Matter Over Thread
Hello
When I send lock command to Nuki Ultra, Lock becomes unknown after 30 seconds. When you look at the logs of HA, in home assistant core it gives the error as below.
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:317
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 1:49:29 AM (1 occurrence)
Last logged: 1:49:29 AM
[139831714351520] Error during service call to lock.lock: InteractionModelError: Failure (0x1)
And when also look at the HA Matter Server logs:
2025-10-29 01:49:29.053 (MainThread) ERROR [matter_server.server] Error doing task: Task exception was never retrieved
Traceback (most recent call last):
File “/usr/local/lib/python3.12/site-packages/matter_server/server/client_handler.py”, line 213, in _run_handler
raise err
File “/usr/local/lib/python3.12/site-packages/matter_server/server/client_handler.py”, line 196, in _run_handler
result = await result
File “/usr/local/lib/python3.12/site-packages/matter_server/server/device_controller.py”, line 717, in send_device_command
return await self._chip_device_controller.send_command(
File “/usr/local/lib/python3.12/site-packages/matter_server/server/sdk.py”, line 308, in send_command
return await self._chip_controller.SendCommand(
File “/usr/local/lib/python3.12/site-packages/chip/ChipDeviceCtrl.py”, line 1552, in SendCommand
return await future
chip.interaction_model.InteractionModelError: InteractionModelError: Failure (0x1)
What can be the possible reasons of this problem? When I interview the lock I get all the information without problems. FW version 5.5.10.
Regards
Gokalp
