HTTP code 204 - but Nuki code apparently not created
We’ve encountered again this issue last week on one of our smart locks.
Here are the logs (reverse chronological order). The lock appeared online, and the API returned a successful response (204 No Content ) when creating an access code. However, the customer later confirmed that the code was never actually created on the lock.
2026-05-18T14:18:28Z  info  ResponseReasonPhrase: No Content
2026-05-18T14:18:28Z  info  ResponseStatusCode: 204
2026-05-18T14:18:28Z  info  ResponseBody:
2026-05-18T14:18:28Z  info  Parameters: {"json":{"name":"XXXX","accountUserId":"REDACTED","allowedFromDate":"2026-05-22T16:00:00+02:00","allowedUntilDate":"2026-05-26T11:00:00+02:00","allowedWeekDays":127,"type":13,"code":"HIDDEN"}}
2026-05-18T14:18:28Z  info  Request: PUT /smartlock/<redacted>/auth
2026-05-18T14:18:28Z  info  Status code 204
2026-05-18T14:18:28Z  info  Request to PUT https://api.nuki.io/smartlock/<redacted>/auth
2026-05-18T14:18:28Z  info  Status code 200
2026-05-18T14:18:28Z  info  Request to GET https://api.nuki.io/smartlock/<redacted>/auth
2026-05-18T14:18:28Z  info  State: ok (0)
2026-05-18T14:18:28Z  info  Checking whether the smartlock is online...
As put it the logs, we check that the smartlock is online, and it was.
How to definitely avoid this?
Thanks!
No answer more than 1 month later, I’m not sure what I can do to solve this.
Hi there,
Following up - still no reply after 2 months. Any feedback from the Nuki team would be much appreciated, this is affecting our customers. Thanks!
