HTTP API callback and the unlatched state
I have recently purchased a Nuki 2.0 with the bridge and it’s working great!
I am using the HTTP API with a callback for state changes, however I have noticed that opening the door, when the lock is already unlocked, will cause an unlocked state change to be sent, rather than the unlatched action that I expected.
I did see some topics about the door sensor state and requests to implement them in the Bridge API. I’m not sure if this is the same thing, as a notification is sent when the door is opened, but its state is not what I expected.
The picture below shows a short summary of what I mean. I have labelled the 3 notifications in the picture. The stateName property from the callback is displayed.
1 is sent the moment the door is opened from the inside. Note that the lock was already unlocked prior to opening the door;
2 is sent once the door is closed;
3 is then sent when the lock is locked.
Callbacks 2 and 3 are expected, but I’d expect the state of 1 to be unlatched.
Is this intentional, or am I misunderstanding something?
Thank you in advance for your time.
There will be no callback for unlatched state. This is by design.
Thanks for your reply!
I did get one unlatched event yesterday though, but I have not been able to reproduce it since.
Not sure how that happened if callbacks should not trigger for that state.
The state change is sent after a completed lock action - which normally does not end on unlatch status.
