I am trying to reach the bridge over a curl request.
Some endpoints are working fine like the /info or /list no issue whatsoever.
The problem is when I try to call /lockState or /lockAction, no matter the authentication method (plain or hashed token) I always get the same result: HTTP 401 Unauthorized.
Bridge Firmware: 2.1.37
SmartLock Firmware: 2.4.5
Here is what I tried:
curl http://192.168.1.103:8080/lockState?nukiId=XXXXXX&token=XXXXX
or
curl http://192.168.1.103:8080/lockState?nukiId=XXXXXXX&ts=2019-03-14T16:17:11Z&rnr=4612&hash=XXXXXXXXXXXXXXXXXXXXXX
Is there anything specific with those two endpoints(/lockState & /lockAction) that must be done prior any call?
Do I have to change any settings in the smartLock in order to make this work?
Thanks a lot
